File types supported by MASSO
MASSO will filter out and only display the filenames having the following extensions in the load file list:
  • .nc
  • .cnc
  • .tap
  • .wiz
  • .txt
  • .eia
shanep
shanep
What does that actually mean?
is it possible to upload a dxf, dwg, stp etc.....generally universally acceptable drawing file exchange formats?
Hi shanep
Masso will not accept drawing files as it is a CNC controller only. It only accepts the file formats listed in the first post.
DXF, DWG and STP are drawing formats used in CAD / CAM software.
@shanep
you will need a cad/cam program to generate the Gcode that Masso, and all other cnc machines run on. There are many brands available, most people seem to use fusion lately and I think it's free for hobbyists. I happen to use bobcad and I just imported a dxf file into it yesterday and generated the g code to cut a sprocket with no troubles. Simple moves can be easily typed out in notepad and run on Masso also.
shanep
shanep
Thanks for the support.
turbocad has a plugin cam module that is similar to mach3/4 and will generate the g code.
so i need to find out what file format the turbocad plugin can output to check compatabiliy with masso.
thanks
moving forward - one small step at a time
