Funny Huanyang Inverter (HY01D523B)
alan
alan
Hi, I've just acquired a 2nd hand Huanyang Inverter (HY01D523B). I have downloaded the manual and am trying to set parameters, but when I press 'set' I get a range, not of PD parameters(which apparently go to PD144 or more) but Pn. from Pn1 to Pn 35. There is no correlation between these Pn parameters and the PD parameters - e.g., PD13(reset) shas values 1-10, but Pn 13 has values 0.0 - 4.0
Can nyone help me with this or have I just bought a bad unit
Hi @alan
I also looked at a couple of manuals from different sites and that certainly doesn't make a bit of sense to me either. Could the vfd be labeled wrong some how? Maybe a photo of the vfd and the identification on it might help???
pinoy-cnc
Pinoy CNC
Quote from alan on April 12, 2020, 7:39 am
hi,
i am using Huanyang inverter,
you need to set up this inverter in this order.
Pd013= 8 (reset to factory)
if your spindle is 400hz
Pd005= 400
Pd004= 400
Pd003= 400
Pd072= 400 (do this step by step)
Potentiameter knob Pd002=1 and Pd070=1
if your spindle is 300hz
Pd005= 300
Pd004= 300
Pd003= 300
Pd072= 300 (do this step by step)
hope this help you
Rex
alan
alan
Thanks for answers guys. I've discovered that the unit is a huangyang look-alike, really an Isacon Askpower vfd, though it is labled as a HY01D523B. From another forum I learn: 'The isacon devices are a special version of the Huanyang. Many of the usual parameters are not available, and they are unsuitable for use with standard induction motors. Special purpose for certain high speed spindles. '
So I guess I'll have to put it back on Ebay!
