G code will not load
rroie
rroie
I loaded the alignment G code holes first. Ran fine. Removed flash drive went to computer loaded cut file. Reinstalled flash drive in Masso now the new g code will not load and the old one is still there.
Thank You
Roie
rroie
rroie
Got it loaded, removed old g code from flash drive and removed (Add side to toolpath name) in Vectric save toolpaths. Should have done the changes one at a time. Do not no what made it work. Only have one set of G codes on flash drive at a time? Will try to load finish pass now.
Thank You
Roie
Roie,
Do you have a Wireless chip installed on your MASSO? Use Wi-Fi Connectivity.
You can also load all your gCode files onto the USB stick from the PC at once, even create a folder structure with them. Then when in the F6 screen use your mouse to open the required folder, select the required file and then click load button.
Only firmware and autoload files are required to be in the root folder of the USB stick.
rroie
rroie
I am going to try and hook up my WiFi this afternoon. Maybe it was the naming conventions that it did not like. I will try to load three or four files on the flash drive and see if I can load them one after the other.
Thank You
Roie
