G3 Spindle speed control
andreb
AndreB
Hello,
I have everything up and running with my new G3 and DMM motors and drives. I have one quick question regarding the 0-10v spindle output on the Masso. My spindle turns on with the gcode commands but the speed does not go over 50hz. I measured the volts coming out of Pin1 in the spindle control connector and the ground pin and all I get is 0.1 volts. I set up the spindle in the settings page so the 10 volts = 15000 rpm and in the mdi, I set the speed to S15000 and all I get is o.1 volts.
Any suggestions?
Thanks for any help you can provide.
