- Why masso doesn't support G31? We need this gcode for feed until skip command so that we can generate modified gcode later according to the surface of our work piece (PCB)? If masso has part probing (g38. 2) then why not g31? I have read a few forums back in 2019 masso said that they are about to add this "auto leveling" feature into their software. But no luck so far. Will masso launch this feature soon?or atleast it should be able to generate a probe data file in ".txt" (which we can achieve using g38. 2 command).... Which can be used by a third party for adjusting the gcode.
