ricardoruiz44
RicardoRuiz44
Hello
I'm Ricardo and I have a 2 plasma cutting tables, one of them is a KALTENBACH machine, it use a Lantek software to automatically nest and create the gcode.
Also, I have a retrofitted plasma table where I installed a MASSO controller and I work with SHEETCAM to manually nest and create my codes,
When I need nest several parts I use my gcode generated on lantek and I import it on SHEETCAM, then just add the plasma operation and run the postprocessor.
This works fine with some parts, but when the parts nested on LANTEK includes circular operation and I try to import this gcode, SHEETCAM doesn't recognize circular operation and modify the pieces.
I upload a file with a example about this
Basically I can see SHEETCAM can't understand the G03 instruction and skip it to next G01 instruction
I hope you can help me.
