Gcode window line display limit
bictonmensshed
BictonMensShed
I have noticed that the gcode displayed stops part way through when running large programs. In the attached photo the last line displayed is N9955
Upon checking where this occurred in Notepad++ it showed it was line 2000.
What is the display window capacity?
@bictonmensshed yes the code that will be displayed in the window will be upto 2000 lines due to memory limitation but the gcode file can be unlimited number of lines and it will run to the end of file.
kiwicnc
KiwiCNC
@MASSO SUPPORT
I'm starting to see many occurances of "memory limitation" statments throughout the forum. Is is possible to retro-fit addition capacity?....what can be done to fix tis moving forward
Ray
