Gecko G203
wbleeker
wbleeker
Hi
can I use a seperate 48volt power supply to run Gecko G203 v drivers? I know I have to use 24 volt for the Masso
Will
@wbleeker
Will,
Yes and it is the preferred method of powering your setup. That way any power problems with drivers will not effect MASSO, also reduce any electrical interference be introduced into the MASSO. Your steppers will perform better with the high voltage supplied to the drivers.
Your 24v PS can be smaller, ie. lower wattage.
