Hi Masso Forum,
A few months ago I converted a G0704 mill to CNC with a kit ( https://www.heavymetalcnc.com/g0704/ ). All is working well with my Masso G3 controller. But what I'd like to do now is control the motor like a spindle/VFR. I recently purchased a Variable Speed Controller card from CNC4PC as I'm a bit afraid to wire the mill's electronics directly to the Masso. Like the Masso the card can convert 5v signals to 0-10v to replicate potentiometer motor speed control and has opto-isolated outputs. But maybe there's actually a safe way to wire directly to the Masso (and return the card).
This mill has a forward and reverse, speed control plus a couple of gear ranges: 50 to 1,125 RPM LOW and 100 - 2250 RPM HIGH. I assume everything but the potentiometer and F/R switch can be left as-is. It's the Forward Reverse switch I'm having trouble figuring out. Has anyone wired one of these G0704s this way (or PM 30-MV etc.)?
Regards
Phil
Regards
Phil
