Hafco hm-46 conversion
ezzupturbo
Ezzupturbo
Hay guys
Have got myself a hafco hm-46 for conversion.
Only a few weeks in still awaiting deliveries..
Obviously running masso controller also awaiting clearpath nema 34 servos
Will be running 2005 ballscrew for x and y and 2505 for my z.
Have ordered a vandle proof ss keyboard with trackball from ebay as well.
Will be running TTS tooling with possibly a 3 tool linear tool changer.
Have a 2.2kw motor with vfd and breaking resistors. Still awaiting encoder for spindle.
Will be running a 1.5:1 ratio to get to 4k rpm from a 2850rpm motor.
Will be updating every few days as I progress.
Any feedback would be awesome.
Regards Chris
Thanks for sharing the info, as you are using clearpaths on your machine, please make sure to wire the alarm signals for each motor back to MASSO for feedback in case of axis issues.
ezzupturbo
Ezzupturbo
Few more bits arrived today
Motor vfd and braking resistors.
Thanks to our local supplier global rewinds.
I think I'll keep the vfd as far away as possible to the controller to eliminate any emf from the vfd. Finally received my bootlace kit as well. Will mount some din rails into my cabinet and start the wiring.
ezzupturbo
Ezzupturbo
So mounted some din rails in my board.
Have long lead time on servos so I'll be making a way forward on my ballscrew assembly.
I have to 3d print up a din rail mount for my resistors.
Also a clearpath power supply to mount in the center. Might also run a din mount gpo.
ezzupturbo
Ezzupturbo
So decided to print a din mount for my resistors..
Both will be on the same mound just with spacers between resistors and mount.
Started the print and when I come back it was green..... Forgot to select second extruder for black filimant.grrrrr
ezzupturbo
Ezzupturbo
8 hours later and it's done. It's green but its done.
Will print out some spacers to suit M6 bolts
ezzupturbo
Ezzupturbo
Spaces done.
1000 line spindle encoder due to rockup tomorrow as well. Not sure how I'll mount that as yet.
We are releasing a new optical encoder that you can point to the spindle pulley and wont need any mechanical engagement, maybe you can use one of these.
ezzupturbo
Ezzupturbo
Quote from MASSO - Support on July 1, 2018, 11:20 pm
When will this be released I'm keen to try it out.
ezzupturbo
Ezzupturbo
And will it be accurate enough for rigid tapping.
I'm guessing minimum resolution will be 1rpm
So I'll have to run the encoder.
Resistors mounted on din rail
