triumph406
triumph406
I have a CHNC that I'm thinking of converting. It's been done using Linuxcnc. But wonder if the Masso control might be easier and faster.
The CHNC turret has a 4 bit output. It requires controlling 3 relays to drive the turret.
The operating sequence would be:
Command turret change
the first relay opens a valve and pushes the turret up to disengage from the location keys.
the second relay opens and supplies air to an air motor to rotate the turret (1st relay still open)
The second relay is closed stopping the motor
the third relay activates a stop that prevents the turret from moving past it's position.
the third relay is closed withdrawing the stop.
The first relay reverses and pulls the turret down into engagement with the location keys.
So how do you control the relays, and how do you control the sequence they operate in? Is there a ladder or code that needs to be edited?
Or do you have turret code that can be edited to work?
Pretty good video showing a CHNC turret in operation
