Have to Load G-Code file twice to run it Problem
skumar
skumar
Hi all,
I have a MASSO G3 running Mill 5-Axis V4.01.
Everything works properly except when I load a G-code file I cannot cycle start.
When I load again I am able to start the cycle and run it.
So I have to load every G-code file twice for it to run.
I do not get any errors when I load the first time, but the code will not run.
Any help would be appreciated.
(htg setting files attached below)
  • MASSO_Mill_5-Axis_Settings.htg
  • MASSO_Mill_5-Axis_Tools.htg
Hi skumar,
Before running a Gcode file you need to press rewind.
After that pressing Cycle Start will run the program.
