Hello from sunny Florida. My CNC vertical milling machine is a modified Grizzly G0619 with a 27.5 inch long table. I originally set it up to work with the Mach 3 CNC control I built for my router and was constantly switching back and forth but recently converted over to MASSO. The conversion involved removing all the lead screws and replacing them with a ball screw CNC conversion kit from Heavy Metal CNC. I also installed a pair of 50 lb gas struts to counterbalance the weight of the head. I am also about to replace the Spindle Motor with a new 1100 watt BLDC motor that is controlled by a VFD Servo Drive. Here is a list of the main components I used for my build. Hope this helps some else join in the Make with Masso movement!
- Grizzly G0619 Deluxe Small Mill/Drill from www.grizzly.com
- X3 Conversion Kit with extended X axis from www.heavymetalcnc.com
- X3 Long Table Kit from www.littlemachineshop.com
- KL23H2100-50-4B Stepper Motors (570 Oz-In) from www.automationtechnologiesinc.com
- KL34H2120-60-4A Stepper Motors (1200 Oz-In) from www.automationtechnologiesinc.com
- KL-KL-5056E Digital Stepper Drive from www.automationtechnologiesinc.com
- KL-8070D Digital Stepper Drive from www.automationtechnologiesinc.com
- 48V/12.5 Amp Switching Power Spply from www.automationtechnologiesinc.com
- MDR-60-24 Power Supply from Meanwell
- MDR-60-12 Power Supply from Meanwell
- MDR-20-5 Power Supply from Meanwell
- BLDC-92GN-31V-ZQ Spindle Motor and AC Servo Drive 1100 watt 7500 RPM from http://hishinetech.com
