I just ordered a Masso G3 and MPG Pendant. I've got a Millright Mega V (19") which we plan to use at our office to machine aluminum parts for a 70mm motion picture film scanner we're building (we do film scanning of 8mm through 35mm on a commercial scanner, but these large gauges aren't really available on most machines). We have already had many of the parts made by a friend of mine with an Avid CNC setup, but I upgraded my old Millright M3 (which couldn't do aluminum reliably) with a Mega V when I saw their kickstarter last fall. Got it all up and running just in time to get shut down due to the coronavirus pandemic. I'm able to get into the office a bit to do some work so I've been tinkering with it and planning some upgrades.
The main reason I got the Masso is because the Millright controller is just kinda cheesy, in my opinion. It's an arduino-based setup that uses grbl and the recommended Gcode sender is UGS. I've had nothing but trouble with it - things like it freaking out when it hits the homing switches, and not being able to resume a job after breaking a tool. I also bought a 1.5kW spindle and VFD to replace the DeWalt router that comes with the Mega V, and UGS doesn't work as nicely with a spindle as other setups. So instead of dealing with all that, I decided to just ditch their controller entirely. I'll be using their stepper drivers, and maybe the power supply and e-stop button. But most likely I'll build a simple box that sits on top of my current enclosure (almost done building it - see attached), with a couple DIN rails inside to hold the VFD, Masso, stepper drivers and power supplies.
Looking forward to getting this soon!
