Hello from New Jersey
kinghong1970
kinghong1970
Hi, I'm Al and I've been bit by the cnc bug for the last decade or so.
i currently have a CNCROUTERPARTS 2448 machine that's been doing ok for me but it was quite a steep learning curve... and still learning.
my current electronics is a G540 system running off Mach3 on an old pc.
i am looking to build new/upgrade, using my current router to make the necessary parts.
the mechanical parts, seems simple enough.
the electronics, well, i've been meaning to try something different. and then i found MASSO... and i think i'm in trouble.
so with the MASSO G3, the documentation seems fairly understandable, but still have some questions but first one being...
do i still need stepper/servo controllers with the Masso?
i am planning for a 2010 ballscrew on the X (Gantry) Axis and contemplating between R&P or Ballscrew on the Y.
Y axis is approx 1.5m travel.
X axis is approx 1m travel.
it's a small machine and i dont need ridiculous rapids... just need to cut accurately into aluminum.
thanks in advance,
Al
kinghong1970
kinghong1970
Thanks for the reply @Arie!
so in essence the Masso G3 or the G3 touch controller takes place of the PC... and the breakout board?
is there a reliable or maybe "better matched" controller that works well with the Masso?
thanks.
Al
@kinghong1970
Al,
Now you are getting me confused. What are you referring to when you say
MASSO is the controller that takes place of the PC & "controller software" and any hardware (breakout board, ethernet board, whatever) used to connect the PC to the machine, where the machine is all that from the motor drivers, spindle controller onwards and any input generating device (limit switches, probes, auto tool measurement, etc).
All modern drivers and VFDs can be made to work with MASSO.
kinghong1970
kinghong1970
@Arie
OMG.... i am confusing myself.
please ignore my previous post... let me do some more reading.
Masso + stepper, need drivers
Masso + servo (clearpath SDSK) am i safe to assume no drivers needed?
thanks again
Al
safeairone
safeairone
Quote from kinghong1970 on March 2, 2021, 5:50 am
Hi Al,
Just a quick note regarding the method to drive a long axis: A long ballscrew can sag under its own weight in the center of its length and, if turned at a sufficiently high RPM (such as when rapid-moving that axis, the ballscrew can begin whipping a bit as the ballnut travels closer to either end of the ballscrew (as opposed to the nut traveling near the middle of the span of the ballscrew, supporting it against sagging under its own weight). Rack and pinions are a way to solve this as they can be made infinitely long with no RPM limitations. A long, FIXED ballscrew with a ROTATING ballnut also solve the whipping problem.
