Help: how to connect leadshine h2-758 easy servo drive
pinoy-cnc
Pinoy CNC
any help here, if they have a english manual of this leadshine h2-758 easy servo drive. i dont know how to connect this to my masso controller.
any help is highly appreciated.
thanks
clover
clover
@pinoy-cnc
You haven't said how many Axis you are using Pinoy. The attached diagram is for a 3 axis setup. If you have 4 or 5 I will work-up a new diagram for you. Attached chart shows pin numbers.
Hope this helps. Cheers, Patrick
clover
clover
@pinoy-cnc
There was a small error on the diagram I posted, it has now been corrected. Please use the drawing above not the earlier one if you have happened to download that one.
Pinoy I cannot find an English manual, I have used Google translate to get the attached from the Chinese manual.
pinoy-cnc
Pinoy CNC
Quote from clover on June 16, 2019, 3:55 am
@pinoy-cnc
thank you clover
roguecnc
New member
@pinoy-cnc
hi clover just a question please the attachment with numbers 3 to 28 do i need to wire all of these for 3 axis router please
thank you steve
