[HELP] How to speed up Z axis ( Maximum Feedrate )
tommylin
tommylin
hi,
Please check my uploaded image, include software version and my Serial number,
I'm so confused about maximum feedrate,
why system change my setting can't over 300 mm/min,
any chances to fix this problem ?
thanks a lot.
The reason you are unable to increase the feedrate is that your setup is generating pulses above 40khz and that is the max frequency that is supported in the current beta software version.
Further if you see the top line in red showing the resolution, its very very high which is not even possible to achieve on the machine mechanically, so please change your drive and MASSO setting from 6400 pulses per revolution to 1600, this will help you increase your max feedrate about 3-4 times.
