This is already documented in the MASSO online documentation:
docs.masso.com.au
HLFB => High Level Feed Back, basically a digital output from the motor to the controller.
With reference to the ClearPath user manual:
The ClearPath IO connector has 8 pins which are allocated as:
- Digital input - Enable
- Digital input - Input A
- Digital input - Input B
- Digital Output - HLFB (High Level Feed Back)
For conformance with machinery safety ("Emergency stop removes all sources of energy from a machine") the Enable input should be driven by the E-Stop signal (Power = OK, Off = shutdown).
When configured for
Step & Direction (typical use with the MASSO controller), the inputs are allocated as follows:
- Input A => Direction
- MASSO D+ connects to Input A+
- MASSO D- connects to Input A-
- Input B => Step
- MASSO S+ connects to Input B+
- MASSO S- connects to Input B-
The MASSO controller only has one digital input for an axis motor - "
X, Y, Z, A, B Motor Alarm Input"
The
HLFB Output can be configured to provide a digital status, available options are dependent on motor configuration:
- All ClearPath operational modes
- Servo On - The HLFB output conducts when ClearPath is enable and not in a shutdown state
- Speed Output - The HLFB outputs a PWM waveform whose duty cycle is proportional to actual speed
- Pulses Per Revolution - The HLFB sends a number of pulses for each revolution of the motor
- Measured Torque - The HLFB outputs a PWM waveform whose duty cycle is proportional to shaft torque
- Positioning Mode (typical mode used with MASSO controller)
- In Range Position - The HLFB output conducts when ClearPath is enable, not in a shutdown state, and position matches command
- ASG Position - The HLFB output conducts when ClearPath is enable, not in a shutdown state, and "Move Done"
- ASG Position Latched - Similar to above, consult manual for details.
- ASG Position with Measured Torque - ASG Position but PWM for torque while moving
- ASG Position Latched with Measured Torque - Similar to above, consult manual for details.
- Velocity Mode (Only used with MASSO controller for spindle motor)
- In Range Velocity - The HLFB output conducts when ClearPath is enable, not in a shutdown state, and velocity matches command
- ASG Velocity - The HLFB output conducts when ClearPath is enable, not in a shutdown state, and "At Targe Velocity"
- ASG Velocity Latched - Similar to above, consult manual for details.
- ASG Velocity with Measured Torque - ASG Position but PWM for torque while moving
- ASG Velocity Latched with Measured Torque - Similar to above, consult manual for details.
- Torque Mode (Not supported by the MASSO controller)
- ASG Torque - The HLFB output conducts when ClearPath is enable, not in a shutdown state, and "At Targe Torque"
By inspection there is only one HLFB mode that only conveys a motor fault condition when the motor is enabled - "
Servo ON". Every other HLFB mode conveys additional information that will be mis-interpretted by the MASSO controller as a fault condition.
The HLFB mode setup is located under the "Advanced" menu of the ClearPath configuration software (just above "Enable Actions...")
