Home Made Small CNC Machine
rdleslie
rdleslie
This is my home designed 3 axis CNC mill. I'm using aluminum for the machines structure because I need to lift the machine up several flights of stairs into a small loft space.
All three axis use hiwin rails, ballscrews and clearpath motors. The spindle is a Teknomotor 2.2KW driven by a Delta VFD-E series. One interesting thing about the spindle is that it allows you to manually change small HSK holders using a small torque wrench.
The enclosure is still being finished at a sheet metal shop, and this will have the Masso and electronics encased at the back.
I plan on anodizing everything once I trust it all fits properly.
that's one very nice looking machine. Please let us know if you have any questions or need any help from us.
agoodevans
agoodevans
Have to agree. Looks very smart. If this is your original design-well done. Not easy to start from scratch. I will keep an eye on your project.
rdleslie
rdleslie
Spindle hooked up, Enclosure Assembled... time to tune the Clearpaths and VFD. Hopefully I can try some test cuts this week!
rdleslie
rdleslie
Masso - Support,
The spindle is purely a mechanical tool change, using a hex key. Here is a video that highlights this well:
The holders are HSK32, which with experience from our large HSK63 machine... gives excellent rigidity.
That is super cool, never seen this before. thanks for sharing. And great work with the machine, cant wait to see it all running :)
