Homing prox switches
rcpartsforless
New member
Hey Guys,
Thanks so much for the help with my last question, it was just the answer i was looking for.
On to my next issue. I had mechanical prox switches on this router prior to changing over to Masso. I was hoping i could use the same switches but i am unable to get the switches to switch between reading high or low. They are two wire switches so im thinking they arent going to work. I have electronic prox switches with three wires, I hooked one up today to see if I can get it to switch between high and low, I was able to do that but it is reading normally high so the control gives me a hard over travel when nothing is near the switch. I do see in the homing menu there is a tick for "invert" is it possible to switch so it is normally low?
When you assign an input to Homing sensors/switches, select invert on the input so that it is LOW when inactive and goes HIGH when activated.
