Homing Sensors
flytyree
FlyTyree
I am not sure if I have damaged or the sensor has failed but, the sensor (for the Y axis) no longer functions. That is the red and green light are both illuminated and when I pass something between the posts the light status remains the same.
I am ordering two new sensors but wonder if the current sensors can be salvaged?
C
x-cnc
X - CNC
Ordinarily sensors can't be salvaged. You should be able to test if it's good or bad though. With both LED's on at the same time it sounds bad, but I would first find out what damaged it before installing a new one.
flytyree
FlyTyree
Thank you for that information.
After close examination there is no wear or damage to the contacts.
Are the sensors normally red and turn green when "homed" ?
Yes if both the LED's are ON then its not normal.
  1. How did you wire the sensors
  2. How much voltage you used to power the sensor
flytyree
FlyTyree
Thank you X-cnc and MASSO.
The lights on the two working sensors are red and turn green when the light is interrupted.
The voltage to the sensors is a measured 5.07 V
The sensors are wired as depicted in the manual diagrahm
I plugged the "non working" sensor into the connector of a working homing sensor and this resulted in the same red - green illumination. To me that confirms the sensor is malfunctioning / bad.
My two new sensor are scheduled to arrive sometime Monday. I am somewhat reluctant to use a new sensor until I do more trouble shooting. The sensors are not that expensive but the shipping to the USA is.
C
  • Yes its a good idea to first find why the sensor got damaged because you might damage the new ones, all sensors are tested before shipping.
  • The only way I can see them getting damaged if 5v was supplied to the sensor output pin or if the voltage to the sensor was more than 5v.
flytyree
FlyTyree
This sensor had been working for quite a few hours and all of a sudden it malfunction during a homing operation. There was no change to input / output.
If the "pin" that was the trigger for this sensor touched the legs of the sensor could that have caused the fault? Even using a magnifying glass I could not see any mechanical damage to the sensor.
