MASSO Serial No: G3-9153
Mill 5-Axis v4.02
Settings file format: v2.30
==========General Settings==========
- Machine units: mm
- Machine bed orientation: Standard
- Load 'autoload.nc' on power up:
- Disable Soft Limits:
- Disable Hard Limits:
- Enable cycle start on door close:
- Limit maximum feedrate:
==========Homing Settings==========
- Seq 1: X: 0 Y: 0 Z: 1 A: 0 B: 0
- Seq 2: X: 1 Y: 0 Z: 0 A: 0 B: 0
- Seq 3: X: 0 Y: 1 Z: 0 A: 0 B: 1
- Seq 4: X: 0 Y: 0 Z: 0 A: 0 B: 0
- Seq 5: X: 0 Y: 0 Z: 0 A: 0 B: 0
- X-Axis Direction Invert:
- Y-Axis Direction Invert: Ticked
- Z-Axis Direction Invert:
- A-Axis Direction Invert:
- B-Axis Direction Invert: Ticked
- Homing Feedrate: 300
- X-Axis Sensor Pull-Off: 4.000000
- Y-Axis Sensor Pull-Off: 2.000000
- Z-Axis Sensor Pull-Off: 10.000000
- A-Axis Sensor Pull-Off: 10.000000
- B-Axis Sensor Pull-Off: 2.000000
- X-Axis Position After Homing: 0.000000
- Y-Axis Position After Homing: 0.000000
- Z-Axis Position After Homing: 0.000000
- A-Axis Position After Homing: 0.000000
- B-Axis Position After Homing: 0.000000
- Request Home on startup:
- Request Home after E-Stop press: Ticked
==========Spindle Settings==========
- Encoder (Pulses per revolution): 100
- Spindle Control Method: VFD (0~10v)
- Spindle RPM at 10 volts: 1000
- Spin UP delay (milliseconds): 10
- Spin DOWN delay (milliseconds): 12
==========Lubrication Settings==========
- Lubricate after: 0(hr) & 0(min)
- Lubricate for: 0(min) & 0(sec)
==========Tool Changer==========
- Tool changer in use: 1: Manual Tool Change
- Z-Axis tool change position: -4.000000
- X-Axis tool change position: -10.000000
- Y-Axis tool change position: 0.000000
- Tool clean air blast time (ms): 0
=============X-Axis=============
- Motor: Distance per revolution: 4.000000
- Drive: Pulses per revolution: 6000.000000
- Maximum Feedrate: 300.000000
- Acceleration: 500.000000
- Travel Minimum: -200.000000
- Travel Maximum: 0.000000
- Backlash: 0.000000
- Direction Invert:
=============Y-Axis=============
- Motor: Distance per revolution: 1.000000
- Maximum Feedrate: 100.000000
- Acceleration: 50.000000
- Travel Minimum: 0.000000
- Travel Maximum: 243.000000
- Direction Invert:
=============Z-Axis=============
- Motor: Distance per revolution: 5.000000
- Maximum Feedrate: 800.000000
- Acceleration: 400.000000
- Travel Minimum: -370.000000
- Backlash: 1.000000
- Direction Invert:
=============A-Axis=============
- Motor: Distance per revolution: 100.000000
- Drive: Pulses per revolution: 400.000000
- Maximum Feedrate: 10.000000
- Acceleration: 600.000000
- Travel Maximum: 1200.000000
- Direction Invert:
- Angular Axis:
=============B-Axis=============
- Slaved to Y axis
- Direction Invert:
==========Auto Tool Zero Settings==========
- Only auto tool zero when manually requested:
- Tool setter X position: -10.000000
- Tool setter X enable: Ticked
- Tool setter Y position: 0.000000
- Tool setter Y enable: Ticked
- Z safe distance to tool setter: -100.000000
- Tool zero feedrate: 500.000000
- Tool number to skip:
==========INPUTS==========
EStop: EStop, Invert: No
Encoder: Signal - A, Invert: No
Encoder: Signal - B, Invert: No
Encoder: Index, Invert: No
MPG: Dial Signal - A, Invert: No
MPG: Dial Signal - B, Invert: No
MPG: Select X, Invert: No
MPG: Select Y, Invert: No
MPG: Select Z, Invert: No
MPG: Select A, Invert: No
MPG: Select B, Invert: No
MPG: Resolution 1, Invert: No
MPG: Resolution 2, Invert: No
MPG: Resolution 3, Invert: No
Analog: Input 1, Invert:
Analog: Input 2, Invert:
Input 1: Cycle Start Button Input, Invert: No
Input 2: Cycle Stop Button Input, Invert: No
Input 3: X-Axis Motor Alarm Input, Invert: Yes
Input 4: Y-Axis Motor Alarm Input, Invert: Yes
Input 5: Z-Axis Motor Alarm Input, Invert: Yes
Input 6: B-Axis Motor Alarm Input, Invert: No
Input 7: X - Home Sensor Input, Invert: No
Input 9: Z - Home Sensor Input, Invert: No
Input 10: Tool Setter Input, Invert: Yes
Input 11: Probe Input Signal, Invert: Yes
Input 13: Y - Home Sensor Input, Invert: No
Input 14: B - Home Sensor Input, Invert: No
==========OUTPUTS==========
Spindle: CW, Invert: No
Spindle: CCW, Invert: No
