How to videos / like put them up ?
lilow
Lilow
DSCF1495
Lets see if this works.
Doesn't.
Does now, how hard is this.
This is possibly the only true 3D Tig welder in the world, it's working with DeskCNC here.
Now to getting it working with Masso and my THC for either Plasma or Tig welding.
Cheers.
Last time I saw something like that James Bond was strapped to it.
Nice looking machine.
lilow
Lilow
See if this works again.
This welding is produced in 3D, TIG machine attached.
It allows me to fully penetrate the material with minimal outside clean up.
This is what I would like Masso to let me do.
Cheers.
lilow
Lilow
More to add now.
With Masso you are now directed to the forum for answers.
The product is great, but there are so many hypothetical questions that could be asked.
Jatindra had a good focus on his product.
There is no instant solution for all the minds that may purchase this incredible product.
With myself, I have had the learning for nearly 20 years to try and get my head around this.
With many different controllers.
Put into the factor of electronics, different field.
Then comes the design plus post processing.
Mine field, it is a learning process.
So after what I have read and achieved, I will dedicate a machine build solely for Masso.
This has been working with 5 axis DeskCNC, was to go to CNCUSB 9 axis.
Not being used at the moment.
But because of an interest in Masso, I would like to get the best out of it using what I know.
Everything shown helps others.
As everyone interested will read these posts worldwide, your little bit of input can make this Masso really work with what you require.
Cheers.
Lilow.
lilow
Lilow
SegoMan.
It becomingly rarer, a Powerglide, set up to handle 1200 + HP.
It's going in my 29 A roadster hiboy.
The last photos before I instigate another post.
Feeling like I couldn't get into any Hot Rod fabrication on this Saturday morning.
Had to change the work mode this morning, so changed some dxf files and cut out another perspex fascia to mount the Masso controller up to a test bed. Now to wire up and test some circuits of the components needed for the application of either Plasma cutting or Tig welding. The start process to really great things.
I will try to set another page to cater for a few things and hopefully get all you guys out there to show what you are doing.
Just discovered.
All outputs on the G3 are now ttl / 5 volt.
Possibly to go hand in hand with a PC command.
Now problem, just change some ideas.
Now to purchase another G3.
Cheers, Lilow.
