Quote from Peter35 on May 30, 2019, 12:21 pm
After using the Mach 3 wizards for quite a few years l found the masso wizards painful to use. I have been using fusion 360 and solidworks with hsmexpress.
I have found the majority of my work needs to be modeled so using these programs are not a problem. They also give me cutter comp.
I am all for the probing wizards.
Quote from steelcogs on June 2, 2019, 5:20 pm
@machinedude You can give a theoretical cutter comp by changing the radial stock to leave.
So if you were doing a 2D contour as a finishing pass and you measured as still having your actual dimensions .01" too big, you could add -.005 radial stock to leave and, in theory, it would tighten up that dimension.
Quote from steelcogs on June 2, 2019, 7:04 pm
@machinedude Yeah unfortunately you have to repost, but I suppose it's better than adjusting the tool diameter on top of reposting. I agree it should be an option on the Masso though.
I've been here but just checking and waiting for backlash comp to come trough.
