First - hope this year is better than the last one.
I have G3 with v4 installed. Been running a few tests after some serious maintenance/bearings replacements.
I have Auto Tool Zero and Tool Change (manual) setup. I Homed and set the X,Y,Z co-ordinates for a test job and then ran T0 M06. The process ran and there was a Z offset in F4 of -1.56996 (I use Imperial measurement). I ran T1 M06 and checked F4 offset which showed -1.57019. I ran T2 M06 and F4 showed -1.57009.
Why am I getting these, differing, offsets for Z axis each time I run the command? I would have expected each Z offset to be exactly the same.
[Incidentally, I tried to capture the F4 screen, a few times to show you folks but, the .bmp file was zero bytes and useless? That hasn't happened in previous versions.]
Robb
Robb
