Increase federate over 100%?
3dlow
3dlow
Could this be implemented?
Sometimes when I post a job I clearly see that I could push it up. Only way to go around this is to stop the job, repost and repeat...
tayloredtech
TayloredTech
Quote from 3dlow on March 23, 2019, 6:52 pm
Yeah, it's certainly a feature many people have asked for. You'll see it requested in a few topics especially the analogue for an analogue input where a potentiometer could be used to ramp a set feed rate up and down. Masso have it on a todo list but don't hold your breathe just yet!
kiwicnc
KiwiCNC
I'm new to this forum and to the product. But as an idea, what I currently do with the MAch3 setup is use a much higher feed rate when I am doing my POST creation, and then throttle back on the interface
Just a thought, and will be the way to use the MASSO
Ray
tayloredtech
TayloredTech
Quote from KiwiCNC on April 29, 2019, 12:14 am
Ray
When you say throttle back on the interface what do you mean? Once the job has started there is no way to change the spindle speed
tayloredtech
TayloredTech
Quote from testyourdesign on March 24, 2019, 1:11 pm
Lol just ran into this issue again last week. Sure would help improve usability.
Agreed, much has slowed in the Masso developments..
Yes this should be on the Masso. Federate override and spindle override are very common and useful
kiwicnc
KiwiCNC
Quote from TayloredTech on July 12, 2019, 10:53 pm
Quote from KiwiCNC on July 12, 2019, 3:00 pm
They are there - use F11 and F12 with the + and - keys
Are you sure?
Never saw this in a firmware release.
Aren't you on a beta?
Mitch
It was working for sure 100% - the alpha for the backlash comp removed the feature - I can downgrade and post a vid once I have change the spindle. I m converting to R8 to get a better release on my ATC - MT3 sux :)
tayloredtech
TayloredTech
Quote from KiwiCNC on July 12, 2019, 11:01 pm
Are you sure?
Mitch
Ok great,
Not sure how I missed it then...
Can you assign an input for +/- ?
Mitch
@kiwicnc does it actually override above 100% I never tried it
