mike_irving
Mike_Irving
Hi everyone, My name is Mike Irving.
I live in Nevada USA near Las Vegas, where Hass is building their new 2.3 million sq ft (213676.992 sq meters) plant.
I was a machinist for 13 years from 69-84 and ran a old primitive paper punched tape CINCINNATI MILACRON mill/drill.
Just mainly drill, tap and slot as it was all manually programmed no canned cycles back then.
My home built machine is built on linear rod bearings, 1000 mm X and Y and a 400 mm Z. It has ball screws with big NEMA 23 motors on XYZ.
The frame is 2" x 2" x .25 wall steel tubing with a fixed gantry. I have a 5 watt laser currently hooked up to the side of the spindle.
The spindle is a BT30 6000 rpm head, putting a 2 hp DC treadmill motor on it for now, possibly updating to a 3 phase motor with VFD later.
