Invertor compatibilities
chucky
Chucky
Hi everyone
I just recently purchased a Masso G3 for my cnc i have just built. I have a Sinphoenix E550 invertor and was wondering if anyone would know if this csn be used with my Masso G3. Can anyone help me please as im unsure how to wire up this invertor to this new controller. Would really appreciate if some could help or has some insight to help.
@chucky,
You can use this wiring diagram as a guide https://docs.masso.com.au/wiring-and-setup/setup-and-calibration/spindle-vfd-examples/delta-vfd-m
  • pin7 to X1
  • pin5 to X2
  • pins 4&6 to CM
  • pin1 to AI
  • MASSO PS -ve to GND
  • Any input to OC. Configure MASSO input as Spindle Drive Alarm Input.
You will need to configure the parameters to use MASSO.
  • F0.00 to 1 External analog input
  • F1.08 to 11 FWD
  • F1.09 to 12 REV
  • F1.13 to 8 Inverter fault
Before connecting the VFD to MASSO please watch this video and follow each step before proceeding to the next, this important as rushing to connect will result in problems with setting up the VFD and MASSO.
