Just a question as I now discover that I build my machine in with the Axis switched around.
also wondering if I'm the only one doing this.
I built the machine to a standerd board size 1220 x 2440 mm. In the lengte of 2440 I have two Axis along side the machine.
Since I got the 4 axis version and you can only slave the X and with the forth one the A, the Y and Z just have one motor.
Now when I put in a drawing and I have my home at the bottom right corner (seen from the top) everything comes out mirrored and 90 turned.
if I could just switch the X and the Y and slave the A to the Y I think I would be fine, but is there a way I could do this just in the settings??
