Is masso able to run Electrocraft servo motors
Hi @jim-in-michigan
You would need to provide the manual for the drives you have to see how they connect but so long as they use step and direction and position monitoring is done within the drive itself then they should work ok.
Some of the older servos used PWM for control which is not compatible with modern CNC controllers.
