kennycritical
kennycritical
So I have just wrapped up getting my Bridgeport mill retrofit with 4 axis Masso control, all AC servos.
I cannot believe the lack of flexibility I have with this controller relative the mach3 LPT systems that I have done in the past.
1: No Backlash compensation? This is a bare bones requirement, I am scratching my head on this one.
2: I have not found anywhere were I can change the rapid rate, There are many applications were steppers might not be able to run as fast as the default setting.
3: When executing rapid moves in 2 axis at the same time, it jerks, rapid any one axis and all is smooth.
4: Single line MDI only wants to execute my code half the time, especially circular moves. (Been a machinist/programmer for 25 years so I know when its my code that is the issue)
5: I asked before purchase if it can home both gantry motors on a router as though they are slaved but independently at the home switch for accurate squaring of the gantry. I was told yes absolutely but I am not seeing how this would function or were it is configurable.
Any info on these things would be helpful, Thank you
