Issue setting tool change position
kiwicnc
KiwiCNC
I encountered an issue tonight whilst setting a tool change position. I probably did this out of order, having not yet setup my AXICES
I could not get out of the menu. ESC...nothing excited ....I had to do a reboot of the system
I have searched the forum and was unable to find a similar issue being experienced
I will now do the obvious and setup the AXICES first next time.....but I think this needs looking at
Ray
the reason you got that message is that the value you have entered for the Z axis is outside what you have set for your Z axis minimum and maximum travel values.
kiwicnc
KiwiCNC
I fully undertand that the values were wroing. hee issue I fasced was with the error message, I could not select SAVE ...and I get that. But I could not step backwards to cancel using any key , inc. ESC
My only resolution was to rest the MASSO
Ray
Hi Ray,
Just tested this on my setup and I just had to use the backspace key to delete the incorrect value and enter a new one then hit save.
