Having an installation issue with random faulting with the G540. I have it connected to a Masso controller.
When the Masso sends Z commands to the G540 it causes a fault, sometimes it will work for a few minutes then fault. I ve tried disconnecting the Z motor from the G540 and it still faults the G540 randomly but only when the Masso sends Z commands to the G540. I m using the G540 with the Charge Pump switch set to off and a jumper as stated. When it does fault, I switch the CP switch to on, then off and it lights the G540 green light, it will work for a short time then fault.
The X and Y axis function normally and will operate without faulting the G540. Trying to figure out if it's the controller or G540 causing the issue. I've verified all connections. Am I missing something or can anyone make suggestions?
Tia,
Neal
Tia,
Neal
