Job Resuming Problem (z position goes deep as it travels to job last position)
eondodge
EONDODGE
Good day,
Anyone encountered this problem with their masso controller and any suggestions for the fix.
I've done a test run and tried to stop in the middle of a job, then i manually stop the spindle and trigger home for the cnc.
Ctrl + J to resume and set the last line i wanna start then click run. The Z then goes down very deep then travels to X and Y position, when the spindle reached the X and Y, that's the only time it goes up then position itself on the actual Z.
Hoping to get a fix suggestions on this soon. Thanks :)
can you please share the gcode file and at what line number you resume your file at, we will try to run the same file and check.
