jog feed rate goes to slow
jim-in-michigan
Jim in michigan
@masso-support
All of a sudden my jog feed rate is real slow, it did work . When I home the mach. I got the rate set to 300. inch/min.When I jog it goes slow like the speed that backs off the home switch. The home button on the F3 screen don't seem to work, if I use Ctrl-Alt-Home buttons it works fine.
So any help would be appropriated.
Hi Jim,
Did you by chance use the feedrate override? F11
If you check the percentage value beside the feedrate it should show 100%, If not press F11 and use the MPG dial or the + & - keys to set back to 100%
Jim,
You need to hold the F3 screen "Home" button for about 3 seconds or more. When it is ready to 'fire' the wording on the button changes (can't remember to what) and when you release the button the homing sequence starts.
