graemegets
graemegets
Im just testing/setting up the Masso G3 on my bench to test it. I just have one Driver and stepper motor on the the moment - nothing else. The stepper is on x Axis (though it does the same on Y Axis).
When I use Jog the stepper only ever moves in one direction. I have played with the min/ Max travel as suggested in another post but no change. If I set the 'Invert' flag the motor still travels in the same direction.
I tested the direction voltages (-3.2 one way, +3.2 other way, +-3.9 when not connected to the driver). the voltage does flip from Pos to Neg when I Jog on opposite direction. The Driver manual seem to want =5v to 24v though but says it can accept differential signal.
Driver : OnlineStepper CL57Y
Closed Loop : Stepper motor (bought as a set with the driver)
I have added the setting file, though not set much up as yet. Also added the driver manual..
Thanks in advance for any help - I'm a complete newbie at this....
