Jump-To Issues
scotoupa
Scotoupa
It seems if I have possibly picked up another bug in the Jump-To in G3 controller V4.02, when I restart on the line needed Masso requests me to load Tool No. 0, this does not make sense as the program has only Tool No. 1
Am I doing something wrong or is there a way around this issue?
Many Thanks,
Scotoupa
Hi Scotoupa
Thanks for reporting this issue with version 4.02. Unfortunately there is a software bug in the jump to line which requests the wrong tool and stops sending the speed information to the spindle.
At this time I would recommend that you return to Version 4.01 so that you have a working Jump to line.
Please note that when you roll back to V4.01 the settings will be wiped as the settings format is not backwards compatible with the previous version.
If you have kept your 4.01 backup then you can reload that but if you saved the settings in 4.02 then you will not be able to use the backup.
In that case take a copy of your printable settings file and screen prints of the various screen as I find screen prints to be the quickest way of comparing and checking settings.
Sorry for the inconvenience.
scotoupa
Scotoupa
Hi Peter,
Many thanks for your prompt reply, do you know when these issues will be rectified?
Thanks,
Scotoupa
