G3 V4.02.
Had to stop a job. Fixed issue and used Jump-To to save some time. The Jump-To check window looked all correct so, I clicked on 'Run'. Spindle moved to correct position and...
...the spindle started to very slowly turn. It descended to the material turning at about 60 RPM. Should have been 16K RPM. I tried a couple more times, to make sure I wasn't making my usual mistakes. Each time the spindle did not turn at the appropriate speed.
I ran the job from the beginning and the spindle started normally and was turning at the correct speed.
Is there a glitch in Jump-To that hasn't been spotted yet? Or, more likely, am I doing something stupid?
Robb
Robb
