Keyboard home button
On the Jog screen (F3) you can click and hold the Home button on the screen until it changes to start and it will home the machine.
You can also setup one of the inputs to be a home button and place a button somewhere convenient.
stevet
SteveT
Hi guy's, first post and still assembling my router. I want to assign the button on the MPG to Home but can't find a diagram. Is it possible through the 15pin plug?
Quote from SteveT on August 9, 2019, 2:01 am
Hi @stevet
welcome to the forum. I don't believe there is a button on the mpg control for homing use. I used a normally open momentary contact push button to send a 24v signal when pushed, to an input on the Masso that was set up to start the homing sequence. Push button can be mounted anywhere convenient. I put mine on the side of the main electrical box. It's easier than pushing the keyboard buttons for the homing cycle, especially since my keyboard doesn't have a home key.
stevet
SteveT
Thanks evermech, this is the MPG I have.
I was hoping that one of the spare pins on the Masso 15 pin plug could be utilised.
stevet
SteveT
@evermech
The button is a momentary and there are 21 wires. I don't have a wiring diagram for it so I will open is up and test.
I will use a DB25 connector to my control box so all the wires / functions are available in the future.
Quote from SteveT on August 13, 2019, 11:24 am
@evermech
@stevet
that should work just fine. Just a matter of figuring out what's what in the mpg. Homing is easily set up utilizing an input of the Masso.
