Hi All,
Just wondering if anyone can offer some support or is having the same issue, since updating to version 3.48 I am having keyboard issues. I have two machines and both are having a similar issues. the keyboard will work for a little while when first turned on, after a short time it will stop working, just thinking about it now, it may happen after uploading a file via the WIFI link. the first machine was when i first noticed, as it is a wireless Logitech keyboard, i thought it was interference or flat batteries, tried a few things, power cycle Masso and also changed USB ports, after a couple of go's, it would come good. The second machine has a Microsoft wired keyboard, I noticed it also had the same issue. The mouse would keep working fine. I was able to start the program and run through the program without issue.
They are the same keyboard that i have been using for a while and the issue has only started since the 3.48 update.
The first machine is a converted TEKCEL unit, previously I could have the cabinet fully closed up and it worked well. Since the update I have had to remove the panel to get the keyboard to work, the Masso is mounted inside the cabinet.
Please let me know your thoughts and any help would be appreciated.
