Lathe-question about some turning operations i missing on interface
romanfox
romanfox
Hi all guy , i am thinking to buy masso like operation system for my smole late but before i will do it i have to collect all information i will need for build up all electric wiring and also tat system do all operation i will need to use .
I am appreciated any cooperation from support team or guys which use lathe or has knowledge about it .
When i check up youtube with masso videos , i can't find any video even in documentation about turning wizard some operation i will need -in masso documentation i find this turning operations
Outer diameter turn wizard
Inside turn wizard
Facing wizard
Drilling wizard
Threading wizard
i check u all 4 times at least and i can't find
taper turning - probably you can set up with outer dia. turn. , same for internal - ok
radius diameter - or inside corner or as a shape it self - missing
internal threading - existing threading has no option for internal threading -missing
grooving , parting - missing - or how to do it ?
Other question is how to join couple different turning operations together?
thank you for your help and explanations regards Roman
