Leadshine MA860H
dbrownproto
dbrownproto
Hello,
I am converting a CNC router from NC Studio to Masso G3 and I have a question about the step/direction inputs to the driver. I have a Leadshine MA860H driver. The manual for the driver states that it can be hooked up in differential mode, however, the driver manual does not provide and example.
If I connect the Masso to the driver in differential mode do I need to install resisters in the four connections? In the driver manual it shows that if you connect the Masso to the driver in common anode mode that a 2k resister is required if system is 24 volts.. See page 4 of the attached document.
I searched the forum for help but could not find a solution
Thanks,
Dave
