Led from TTL outputs on G3
diegocolonnello
diegocolonnello
Hi guys, on your documentation about Tower lights it says:
Tower lights can be wired to MASSO outputs to provide visual indication of machine status.
Taken from:
https://docs.masso.com.au/wiring-and-setup/setup-and-calibration/tower-lights
Does this mean i can connect my LEDs directly between Negative and any output on my G3?
All the outputs say TTL... as ii understand the outputs can drive a max of 5 mA
I have tiny 5 mm leds inside my Panel Buttons, do i need a relay board to switch them on?
Thanks so much
Diego.
