Can someone help me configure the Lenze VFD. It runs fine with the keypad but can't get any movement thru the Masso. I've wired it correctly according to the Masso/Lenze wiring diagram and checked to make sure it is all wired correctly. The only thing different I did was run a jumper between terminal 1 and 2 on the VFD since I am not using an E-stop there.
The VFD is rated for a 3 HP and I have a 2 HP motor. The VFD model is ESV222NO2YXB.
The Manual is here, https://download.lenze.com/TD/ESV__SMV frequency inverter__v21-0__EN.pdf
The parameter start on page 27.
