mtlchsr
Mtlchsr
Hi, I have wired my machine limit switches (1 x each on the Z, X & Y axis for a total of 3 switches. Standard lever type switches. NC configuration. One common power wire from the Masso G3 PWR red block to the 3 switches with separate wires back to the inputs) and assigned inputs in F1 screen. When I start Masso (and go through the e-stop + login etc) I have green 'Ready' led light and no red 'Error' on the unit as well as no alarms in the main screen- all good. In the F1 the assigned limits are all reading 'Low'.
If I manually trip any of the switches they will read 'High' and go red and return to 'Low' and green when I release the switch.
2 issues though. 1) When I trip the x switch both the X & Z go to 'High' red...... and then return to low - green 2) When I trigger any of the switches the 'Hard Limit 'alarm comes on in the main screen and stays on. Any Ideas ????
