At first I love my masso CNC controller.
Tool Change runs great, and I have 11 Slots and all runs great, but I have one issue and don't know how to fix it.
If i make a T1 M6 for example the ATC changes the tool all great and all the same with all 11 Slots, but if I want to to load for example T12 M6 (this tool has no slot in the toolchanger because it dosn't fit like my 60mm surface milling bit) i want to make a manuel toll change like I can do it with tha manuell tool change (https://docs.masso.com.au/wiring-and-setup/tool-changers/mill-tool-changers/manual-tool-changer)
The controller makes an error and tell me there is not slot for this tool.
How can I make a manuell tool load during milling?
An example
T1 M6 (there is a slot the tool is loaded and all work)
T12 M6 (this tool has no slot, but the controller does not make a manuel Tool load) ---> How can I load this tool?
T3 M6 (there is a slot, the tool is loaded and would work)
Thanks I hope somebody can help me, I searched the forum, but I didn't found an answer.
Best wishes Daniel from Germany
An example
