linear Tool changer (type1) issue
Hi Pinoy CNC
That's definitely a problem.
Can you upload a copy of your Printable settings file as well as a copy of your Settings.htg and I will take a look for you.
we looked into this further and the logic is working as expected, Tool Changer - Output 3 goes HIGH and then LOW as soon as the sensor is reached. In your setup how is your pneumatic cylinder setup and wired?
As per the MASSO logic, there has to be two outputs to control the pneumatic cylinder, in your setup do you have one or two lines to control the movement?
pinoy-cnc
Pinoy CNC
Quote from MASSO Support on January 29, 2021, 7:54 pm
hi Masso Support and Peter,
sorry for late reply super busy yesterday, i done a little test this morning base on your idea but no luck.
here is the video that i took this morning.
i am using 2 solenoid valve to control the up and down also two proximity sensor for up and down
pinoy-cnc
Pinoy CNC
here is the machine setting of my machine
  • MASSO_Mill_5-Axis_Settings.htg
  • MASSO_Mill_5-Axis_Tools.htg
Hi Rex,
I see in the video you have Tool Changer output 4 inverted to be High normally.
It's normal state should be low.
If you look at the Tool Changer logic step 15 the last thing it does is change the output 4 to Low.
This is why the tool tray is retracting when output 3 goes low.
Remove the Invert on Tool Changer output 4 so that it shows low and give it a try. It should work properly.
Let me know how it goes.
pinoy-cnc
Pinoy CNC
Hi Peter,
when i inverter the tool changer output 4 to low the tool tray are in the middle of the linear rail because the solenoid valve is in the state of low(no air pressure going to the cylinder)
on my understanding that when the is the following, please guide me if i am wrong.
1. Tool Changer - Input 5 for Tools Tray DOWN OK signal (always high state, it will in low state when the tray goes up)
2. Tool Changer - Output 4 to move ToolsTray DOWN (always High State, because this will push the tray down, it will be in low state when Tool Changer - Output 3 to move Tools Tray UP in high state)
3.Tool Changer - Output 3 to move Tools Tray UP (it will high state when of tool change called and stayed in high state during the tool change after that its goes low and Tool Changer - Output 4 to move ToolsTray DOWN ( goes to High State, and push the tray down, and wait for another tool change operation called Tool Changer - Output 4 to move Tools Tray UP in goes high state again)
also here is the video of F1 screen Test
rossco
rossco
Rex:
I experienced the same issue and resolved it by using TWO relays , output 3 operates a relay No 1 closing the NO contacts to operate the solenoid, and the 2nd relay operates as a latching relay to hold in relay No 1 until energized by output 4. This allows the solenoid to operate and maintain air pressure once output 3 has been energized even if denergized until output 4 has been energized.
Also use similar for dust hood operation
Trust this helps
Rossco
Cncmaatwerken
New member
Hi Rosco, can you show me an example of how that's set up? I run into the same issue, having no sensors for dusthood of clamping postions. Figured i can wire an output/relay to an input for the signal. I am able to get the tool clamped/ u clamped and dust hoor up/down.
Thanks!
Hi Cncmaatwerken
Just to let you know that you do not need to do to such lengths if you do not have a particular input on your Tool changer.
If you do not have a sensor on your tool changer just do not configure an input for it and the tool change logic will ignore it and move on to the next step in the logic. The same applies to outputs as well.
I notice that this has been omitted from the tool change pages and I have now added this note to them.
Cncmaatwerken
New member
So if i understand correct, i don't configure inputs for spindle clamp and dust hood, just the up/down and clamp/unclamp outputs?
Thanks!
That's correct.
If you don't have need on an input or output on your tool changer then do not assign it and the logic will ignore it.
Cncmaatwerken
New member
Thanks, will have to build a new tool rack first... then i will let you know :) converted a chinese 2030 machine from NK105 to Masso everything looks good and smooth so far.
Cncmaatwerken
New member
Conversion is great, machine runs nice and smooth! only thing is it's cutting parts outer contours 0.6 mm to small, and holes inner contours also to small. Probably not the right topic, but maybe there's is a topic about that... did a search did not really find something. tried backlash, but unfortunatly seems to do nothing how's the logic about backlash in the settings screen
Thanks Joey
