dylan-hydronalix
Dylan.Hydronalix
Hello,
I have experienced a couple of issues during long cuts, and am curious to the cause of them and a potential solution.
First off, during long programs, think over 24 hours, I have experienced an issue with tool changes and the auto tool zeroing function. It will get the end of the cycle and ask for a tool change, which when complete will touch and on the z axis probe as it should. However, the controller will act almost as if it forgot to update the z axis height for the new tool and use the previous offset. I have attached a picture of one such occasion, where the bit took a bite of the material because we had switched to a longer bit. It appears that if we run each cycle on their own individual programs, turn the machine completely off and then re-home it in between programs that it will function properly. For obvious reasons, this is not ideal and a potential safety issue. I feel what potentially causes this, is the controller running out of memory, as this appears to only happen when the tool change prompt is allowed to sit for an extended period of time.
In the same vein, if the machine is emergency stopped, and set to continue the program or even if the program is restarted, the machine will act unpredictable. The machine will make random movements in a random direction at a random point. Again, if the machine is completely restarted and homed again, it will function correctly. I feel that this is again a memory or cache issues.
Finally, is there a reason that the fourth and fifth axis units are in inches and not angles? Is it possible to change this?
