safeairone
safeairone
BACKGROUND:
Was alternating back and forth between G54 WCS programs (some facing operations close to X0, Y0) and G55 WCS programs (long cuts that require more X than my current G54 zeros can give) all morning.
Machine was then left to idle for several hours after last running a G54 program.
ISSUE:
Loaded same G55 program I was running earlier but got this error as soon as I rewound & cycle-started:
I re-loaded the program several times, including changing the program in memory between loads, but got the same error each time I tried to run the G55 program.
I cycled the power to the machine, but still got the error each time I tried running this simple program (I’m just slicing 96” long piece off a 4’x8’ sheet of 1/4” pvc using a 1/8” end mill).
I decided I should check that it didn’t somehow lose my G55 zeros, so I MDI’ed G55 [run], then hit the “Go to work origin” button, which it did, exactly where it should be for the G55 WCS.
I decided to try the G55 program one more time, at which time it ran normally, without the error.
CONCLUSION:
I think the controller got stuck in G54 mode and didn’t see/change to G55 during the look-ahead math it was doing. Definitely too much “X” for the G54 WCS, hence the use of G55 in this particular program.
ISSUE:
CONCLUSION:
