Masso encoder for lathe software problem
dup
DUP
Hi Chaps
Been struggling for three days to get an RPM readout on a lathe using lathe software version 3.46.1
On the F1 screen, the "signal A" and "signal B" go high with the passing of each one of the outer markings on the disc
The :Index" tab goes high once every revolution with the passing of the inner marking on the disc.
However, the Index tab does not count up with each revolution as it should and also there is no RPM readout.
Please could someone point me in the right direction so that I can get on with threading.
Thanks guys
Regards
DUP
@dup
as mentioned in the software email notes, the RPM is not displayed in the current software version due to some new logic additions and will be available in the next upcoming software release. You can still do threading but it's just that the RPM won't be displayed.
